mike90040
- Los Angeles
Good Day to you all, I have a few questions I'm going to ask for help with, #1 is on a job I'm doing there is a plating room and the main chemical used is Nichoal sulfate. What kind of conduit will be up to code to use? PVC sch 80? Ridge pipe? sealtight flex? or rob roy? My second question it I have a 400amp sub 480v aprox 120' from main 350 or 500 mcm? and last Question I need to add a 75 kva trans 480 pri 120/240 second what size should the disconnect be fused at? 120 amp or 200 amp I'm thinking 120 as I'm bucking down? I really appricate all you who will reply and share you knowlage with me as I'm working on my first big project and it's an as built, have a GREAT DAY!
Mike90040
Mike90040
