drcampbell
- The Motor City, Michigan USA
- Registered Professional Engineer
I'd like some help identifying this sensor.
It's mounted behind a big pulley that will turn about 600 revs/minute, that has one big iron slug that passes close by the sensor with each revolution. The label is either missing or completely unreadable.
It's called a "revolution guard" in the (somewhat sparse) documentation. I suspect its purpose in life is to turn off the drive motor in case the machine stops turning because something jammed or broke. It's a 90 kW motor, which could wreak considerable havoc.
It was originally configured for 220 volts, 50 Hz. (Denmark) I hooked it up to 120 volts, 60 Hz and a small linear load. (a 7-watt Xmas-tree bulb)
It turned on the lamp for about 20 seconds, then turned it off. The red LED on the back of the sensor lit up at the same time.
Turning the pulley by hand (~1-2 revs/minute) and passing the iron slug slowly past the sensor did not elicit any response. Both lights remained off.
The same thing happened when hooked up to 220 volts, 60 Hz and two Xmas-tree bulbs in series.
I have the book for the controller, but not the controller. I'm in the process of building a new controller.
https://i.postimg.cc/TpZJRLWh/rg-sensor-side.jpg
https://i.postimg.cc/LhQVb09t/rg-sensor-front.jpg
https://i.postimg.cc/hfJ0WbvH/rg-sensor-back.jpg
https://i.postimg.cc/D40Pz1g4/revolution-guard-wiring-diagram-highlighted.jpg
