Please help identify this breaker
Alexis
Los Angeles
Hello,
It seems to be square d, but I can't find anything similar in any searches.. legs look like QO, but I don't think that modern ones would fit..
Thank you!
Obsolete Square D type MO-4.
I thought the MO4 family was originally from the 1930s but the earliest panelboard I could find was from the late 40s.
I’d be hesitant to swap in a refurbished breaker. I wouldn’t think a manufacturer would discontinue a line unless there were some inherent safety issue (looking at the breaker, probably the clips tended to wear out and then arc).
Most redesigns are for cost reduction.
I don’t know about that style, but Square D has retrofit kits for other obsolete breakers that allow a QO to be used. It has bussing that you install to the old buss to adapt. Might pay off to check with your local Square D distributor.
