ThomasMartin
- Milwaukee, WI, USA
Is there any exceptions where plenum rated cabling is not required above a plenum ceiling if the plenum is dedicated for a single space. My understanding of the intent of the code is that toxic smoke will not spread between multiple rooms per single plenum but if single plenum space per room what difference would it make where the smoke originated? The NEC does not seem to address this? Preference is to use cable bus wiring with free air ampacity rating in a plenum space for a large data center installation where no options for plenum rated cabling exists. The owner has many sites where this has already been installed and the AHJ had not raised as an issue during permitting or installation.
