fandi
- Los Angeles
- Electrical Engineer
Hi,
I'm trying to figure out a 30 ft 4000A ductbank to connect a 2.5MVA transformer of utility company (I secondary = 3000A) to a new 4000A 480V switchboard. Usually the utility company do this but this time the owner is responsible because the meter is on the utility transformer primary side.
The transformer room is underground and the new 4000A switchboard will be installed on grade outdoors.
I can't use Table 310.15 (NEC 2011) because of the heat generated between the conductors and I don't have a computer based Neher Mc Grath program to calculate.
I know there are many configurations of ductbank but I just want to know a general idea of:
- Is that a concrete encased ductbank?
- typical rows of conduits.
- typical wire size to be used? Is that 500kcmil?
Thanks a lot.
Thanks a lot.
