Glennwith2ns
- Pennsylvania
Awhile ago I asked this question and I would like to ask it again in a different way.
240.50 Plug fuses
(A) Max. Voltage
Plug fuses shall be permitted to be used in the following circuits:
(1) circuits not exceeding 125 volts between conductors.
(2) circuits supplied by a system having a grounded neutral where the line-to-neutral voltage does not exceed 150 volts.
Feeding a typical 220 volt line in a residential application to a 2-fuse disconnect would seem to comply with no.(2) but not with no.(1).
Is this a situation where one or both rules must apply and where would this be stated in the codebook?
I also note with interest 240-60 Cartridge fuses:
(A) Max voltage
Cartridge fuses and fuseholders of the 300 volt type shall be permitted to be used in the following circuits.
(1) circuits not exceeding 300 volts between conductors
Why plug fuses limited to 125 volts and cartridge fuses 300 volts??
Glenn
240.50 Plug fuses
(A) Max. Voltage
(A) Max voltage
Glenn
