Has anyone here had experience using the QO brand plug in type secondary surge protector? The specific product I'm looking at is the QO 217SB. The current panel arrangement at the job in question is a 200A main breaker feed through panel located outdoors. Coming off the feed through lugs is a 200A indoor panel located inside the residence. There is also a 100A 2 pole subfeed from the bus of the exterior panel feeding a sub panel at the opposite end of the dwelling.If the surge protector device was installed in the exterior panel, would it protect everything "downstream"? Another question. Why is the product described as "secondary" proteprotection? Is there such a thing as "primary" protection? If so, what would be required to achieve the that protection? Thanks much for any help
