Plumber is putting an air-jet tub in a 3-wall alcove. It's not a hydromassage tub and no special grounding is needed. The Blower/Heater has a normal 3-prong plug.
Access to the Blower/Heater is through a cut-out panel in the back of a closet adjacent to the bathroom (behind the head of the tub). I had intended to put a junction box in this crawl space, direct-wire the tub, and put a blank-face GFCI on the far bathroom wall, both for convenience and as an emergency cutoff switch.
However, since the tub has a 3-prong plug it seems like I should mount an outlet on the junction box in the crawl space.
I don't like the idea of a plug/outlet that can't be seen and is inaccessible. Vibrations could loosen it, etc. But I'm not sure I should be cutting off the tub plug.
Which is safer? Cut off the plug & direct-wire, or leave the plug and put an outlet in the crawlspace? (I suppose I could use a regular outlet and still put the GFCI on the wall, but that seems kind of hokey).
Thanks!
/j
[ September 28, 2004, 05:53 PM: Message edited by: jeffw_00 ]
Thanks!
/j
