Re: Plug Supplied Industrial Machinery
I appreciate everyone's responses. I've read that the NEC code is considered a "challenging" document, but it seems to be turning into an engineering version of the tax code.
Based on NFPA 70 and 79 Which scenario is a code violation?
1. 10hp machine, onboard O.L., hinged screw cover electrical enclosure, supplied by a G.P. branch receptacle/plug.
2. Same as above, plus a HP rated safety switch next (adjacent) to the enclosure, not interlocked. Still G.P. plug supplied.
3. Same as #1, but the disconnect is a safety switch is on the other side of the machine (still visible). Still G.P. plug supplied.
4. Same as #1, but the disconnect is panel mounted in the enclosure and interlocked with the cover. Still G.P. plug supplied.
5. Same as #1, but the disconnect and supply is a HP rated plug and receptacle.
6. Same as #1, but add a panel mounted rotary disconnect, interlocked with the cover, and a HP rated plug/receptacle disconnect.
Can our AHJ approve any other scenario regardless of the common consensus made here? :roll:
