M Machiavelli999 Member Dec 10, 2013 #1 Are plugs allowed to be attached to wiring that is not considered "flex cable" as per the code? Are there any restrictions as to where plugs can be installed?
iwire Moderator Staff member Location Massachusetts Dec 10, 2013 #2 There would likely be listing issues with the cord connectors. 110.3(B) There would be issues of mechanical continuity as required of chapter 3 wiring methods. 300.12. There would likely be support issues of the cable type used. 3XX.30.
petersonra Senior Member Location Northern illinois Occupation Semi-retired engineer Dec 11, 2013 #3 you normally cannot connect plugs to cable, only to cord.
