I will not question whether the couplings have a taper, but that is not why pressure forces the joint apart. The pressure multiplied by the cross sectional area of the inside of the pipe is the source of the force pulling the joint apart
The pressure is when you are gluing the pipes together, the taper and the glue will push the pipe out unless you hold it for a bit.
This is different from the hydraulic pressure in the pipes. In large water mains, 6", 8", at corners and water meters, there is typically a yard of concrete as a thrust block. We have some 36" dia pipes and those have huge thrust blocks, many yards of concrete
Huh?In the sizes larger than 1?", plumbing pipe is usually cellular core, which means it's not mean for water pressure and is limited to drain/waste/vent. Electrical conduit is solid core.
Take a look at a cut end of both and you'll see the difference. The cut end of white plumbing pipe will look like foam.
Huh?
I just used some 2-1/2" Schedule 40 PVC plumbing pipe, it was rated 300 psi
There is cheaper white plastic pipe that is rated as DWV (Drain Waste Vent) only, not the same thing.
I know of one plumber that primarily uses only 20 foot lengths of sch 40 (never any cellular core either). Those that he uses have bell ends. He also told me by using 20 foot lengths he seems to not have as many short scrap pieces as most do if they buy it in 10 foot lengths.Electrical lengths often have bell ends. Plumbing lengths don't.
Electrical bends have a larger radius than plumbing elbows.
Plumbers do not use conduit bodies.![]()
Pick them both up and there will be noticeable weight difference as well.In the sizes larger than 1?", plumbing pipe is usually cellular core, which means it's not mean for water pressure and is limited to drain/waste/vent. Electrical conduit is solid core.
Years ago I was repairing a sprinkler & there were 3 PVC pipes close together so decided to cut the other two out of the way, big mistake, one of them had a 14/2 UF inside it, not on, or powered up but still gets me riled when I see plumbing PVC pipe used for electrical.
