Eric E
- Pennsylvania
- Engineer
Hi everyone. I’m working on a residential install that includes a structured wiring enclosure into a non-bearing wall. It’ll be used for a fanless network switch with some CAT6 PoE. The studs have only 13" of spacing, so nearly all standard enclosures (~14.3") won’t fit, except ones that are too small (e.g. 12" x 14”). The client (a woodworker) wants to build a 13” x 28” cabinet box from plywood. It’d use a commercial vented enclosure door and there would be sheetrock-deep flanges to even out the width difference between the cabinet and the door, so it should look clean. It’d have a power outlet in a standard J-box mounted in the bottom of the cabinet. Everything metal and all equipment would be properly grounded.
Since this is so far from the normal metal/plastic structured wiring enclosures I’m used to, is there anything in the NEC that would prohibit the use of an in-wall plywood enclosure for LV wiring / network equipment?
