PMG Excitation Generator
W@ttson
NJ-USA
PE
Hello All,
I just wanted to see if anyone had experience with PMG type excitors for generators. I have always been told that they are used in generators that are going to be supplying motor loads or a lot of VFDs since the noise from the drives do not mess up the voltage regulation algorithm. I know that they are good too for short circuit capacity. Does anyone else specify them? For what applications? Is there a minimum size you specify them on? Should they be specified for all motor/drive applications?
