POE for a camera
Hfalz1
Houston, Tx.
What is the max distance for POE (power over ethernet) on cat6 for a camera?
[adding characters to make sure we reach 100 limit for a thread starter post. aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa]
Your Ethernet won't go 450', it's limited to about 330'. If you need to get out that far, you need to either run fiber for the 'net and maybe 18g copper for power or put a network switch (repeater) somewhere along line (which will need power) and put the PoE supply out there.
There are fiber media converters that also act as PoE supplies, but they still need to get the power from somewhere (e.g. http://www.antaira.com/products/poe-converters/FCU-2805P-SFP or https://www.perle.com/products/10-100-1000-poe-industrial-converters.shtml#overview; I haven't needed to use either unit).
rambojoe
Wireman
phoenix az
Wireman
Can't multiple pairs be paralleled?
that's a no... besides the electrician way of thinking...you still have to terminate it in a jack- which will not allow it... for the OP, id call the manufacture and confirm... im not sure why it wouldn't work with the booster. ethernet doesn't mean that the video signal is wireless... its still hard wired to a dvr...
hbiss
EC, Westchester, New York NEC: 2014
Hawthorne, New York NEC: 2014
EC
Assuming that the ethernet connection only requires two pair (some use all four), you could parallel the other two for power to reduce voltage drop. However you still have the data distance limitation of 333 ft. on the data pairs. So that's not going to help. You're going to have to get your POE switch closer to the camera or figure out a shorter route. A better way is to run fiber with integral power conductors out to a fiber/ethernet converter located with the camera.
-Hal
dpcarls1598
Master Electrician
Minnesota, USA
Master Electrician
I have used a coaxial converter that carried both the data and power longer that CAT cables. I have one about 1,200’ with a single coax. The POE camera is a pan tilt zone with heater about 80’ up on a stadium light pole. I don’t know the manufacturer but our camera vendor supplied it.
Easy install with no programming. Been flawless for about 4 years now.
Gary11734
Florida
Take a 500' box of Cat 6, Hook up the camera and power and see if it works. Leave the wire in the box. Also, you can see what the VD drop is. If it works, it works. The worst case scenario is it will probably work but have some dropped frames. You may not notice.
I'm not saying I would install and charge someone for this, but to see if it would work. I say it will.
The 100m is for data to make the spec of the cable... I'm not sure, but the video may be running under UDP, not TCP which it doesn't matter if some frames are dropped. It will keep pushing out the signal no matter how the screen looks since the Ack/Nak is different... I think I explained this to be clear as mud.
(Don't bet on that.)
However it probably won't, and it surely won't pass any certification test, which most customers insist on.
Doesn't matter about TCP/UDP/or whatever layer 3 protocol; it's a layer 0 and 1 problem. They may cause problems at layers 2 and above.
So, sure, try that as an academic exercise, but it would very bad practice to install TP ethernet over 100m (330').
Gary11734
Florida
Exactly what I said. All academic. Maybe I'll put one through the test. I have a bunch of Panasonic IP's on the self. I still would like to know what the VD is in the real world scenario. As far as 0 and 1's, I wonder if it knows when it goes over 100 meters, lets say to 101? The certification is based on the speed of which the cable is saying it will perform at. I can't remember what certification number it is. Being a ham and tearing everything up in the garage from engines to building Heathkits, and now Arduino projects have their downsides in my inability to not tinker with the stuff.
It doesn't of course know exactly. Some transceiver/cable pairings will reliably work past that, but it's still out of spec.
As a ham, think about this as an 125MHz* balanced analog transmission line, not as 1's and 0's. You have not only the DC resistance of the line, but the distributed reactance and pair-to-pair cross-talk. There's also the slight difference in length of each pair due to the different twist ratios; the PHY at each end is supposed to deal with that. For some light reading, or a headache :D, look at the Ethernet physical spec... there's a lot of wizardry involved; it's rather interesting if you're into the low-level workings.
*not actually correct, IIRC the rate is 125M baud (symbols/second, not bits/second)
Kind of amazing that it works at all :happyyes:.
Gary11734
Florida
The spec will get people where they can't see the forest for the trees. I live inside the box when in business given that I have to meet spec. But, I'm always thinking outside the box when it comes to why things work in the first place.
The key is, would it work if I pull a 500' of Cat5E off the self and fire it up with the wire still in the box? I say, yes! If not, well no loss here.
Ah yes, the seven layers... I passed the Microsoft IT Pro course years ago. I figured the data cabling wasn't the big deal. Now those guys that can make 100 cables look good in a tray is impressive. Punch down is BORING! Getting in front of the owner where you do the backbone supplying the switches and the routing tables was a better way to go. I started working on my RCDD a few years back but I just get bored when it comes to data.
caribconsult
Añasco, Puerto Rico
Retired computer consultant
Have you considered the option of going WiFi on this? With a good transmitter and receiver, and possibly some narrow focus parabolic antennas on each end it might work. POE does have a distance limit and as you get there, speed drops and reliability of connection becomes more of an issue.
DrSparks
Madison, WI, USA
Beat me to it. I was just going to recommend a directional WiFi link. They make small outdoor directional antennas for pretty cheap. Check out Amazon and Ubiquiti Networks' stuff. Of course, you'll need power out there unless you do a solar/battery DC system.
Adamjamma
camera uses dc, transmitter probably uses dc.. amplifier would use dc as well... tigh pattern UHF using can system for transmit/receive... the higher the better to cut down on distance and interception likelihoods... hmmm... as a ham operator I am intriqued by the idea but not sure what frequencies could legally be used for an unlicensed security link... of course, if you are not worried about interception of signals then commercial gear is available... but looks like a linking system for repeaters would work here...two of those micro computers, one at the area you want the cameras, for controlling them... one at the security site for decoding and saving the actual signals... you would be able to actually put several cameras at the remote area that way, if needed...
Of course, a dedicated wireless router on a directional wifi antenna could do the same... Shame I am no longer in Virginia or would go up on the tomato net and find the guys who already been there done that as a fun experiment..lol...
