Point me in the right direction
Earthshakergb
New member
Gothenburg, NE
I tried to locate this in the 2011 NEC, is an unattached garage considered a separate building, accessory building or a auxiliary building?
Here is the situation I have a garage that I want to subfeed from the house. I read in the code that I need to run a "feed", from a breaker in the main panel, to the garage. I would go underground, as opposed to overhead, is a 4 conductor cable, required overhead only? underground? or both. I found this once I cannot find it again.
Yes it is a separate structure and article 225 part II applies
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
