Jerramundi
- Chicago
- Licensed Residential Electrician
So, an interesting question come up in the course of reviewing some plans for an overhead service.
Does anyone know if the NEC specifies how far the point of attachment has to be from the edge of the building?
This is assuming all standard vertical and horizontal clearances (e.g. vertical clearance requires the POA to be moved inward 3 ft, etc.) have been met.
I've never really encountered it as a potential issue before. It's either on the riser itself or there's always been plenty of building to work with.
I feel like a minimum of "3 bricks" should be required as an explicit metric, haha.
Again, POA from edge of building....
Thoughts?
Thoughts?
