I would like to re-fasten my service drop to my house. A tree limb fell on the drop and pulled at the point of attachment, an anchored insulated fitting, pulling the insulated fitting out of the house brick. The drop stayed up off the ground although.
The service drop is a tri-plex with two insulated conductors (both phases) wrapped around bare strands of aluminum (the neutral). Woven with the aluminum strands are several bare strands of steel (the messenger cable).
For the new point of attachment, I intend to pass a threaded metal eyebolt through the exterior brick and place a metal plate against the inside wall, inside the stud run, and nut the metal plate secure. I would then conceal this with drywall.
Outside, I intend to pass the steel strands through the metal eyebolt and rewrap these strands around the bare aluminum and split-bolt all the bare strands together for strength.
Is this an electrically safe installation? The bare steel and aluminum strands are wound together and are attached to the metal eyebolt making this eyebolt current carrying (the unbalanced load) into the walls of the house.
I would like to avoid the use of insulators since tree limbs fall often and could snap in two the insulators causing the service drop to fall again.
Thanks
Thanks
