Hello,
I am new to the forum and the electrical industry and I am just getting into that not so easy field.
It is maybe an easy question for most of you guys but it bothers me and I am not sure about the answer.
The building that I am proposing a solar system for has one 800 amp main disconnect which supplies 7 meters with adjacent disconnects. 6 of the meters supply 150 amp disconnects and the 7th meter (the one getting solar) supplies 2 200 amp disconnects. Here is my question. Would my tap between the 7th meter and 2 disconnects be considered a load side connection which would fall under the 120% rule or a supply side connection? I believe that this is a load side connection and would require upsizing the feeder between the 800 amp disconnect and the meters to connect a system larger than what the 120% rule would permit. Please let me know if I am close in my thinking or if I am way off.
Thank you in advance !
