I'm curious to hear what process others use for doing point to point wire checks in the field between two distant locations. Usually within a same equipment enclosure or panel its easy to just use a meter to connect directly to both ends of a wire but wanted to see how others went bout it where two panels were remote from each other?
I've seen both meters and phones used in the past with one end of the meter/phone at each end of wire connected to ground and the other end connected to the circuit wire in question?
