bstright
- Harrisbug, Pa.
We miss oriented the anchor bolts in a concrete base, do you have any solutions to this outside removing the concrete base and replacing it?
We have cut them off flush and replaced them with new ones that were epoxed into the base.
However, this was an engineered solution with an engineers stamp and approval to provide both the customer and the inspector.
(In our case the pole manufacturer had sent the wrong templates and they paid T&M for the repairs)
I saw this program called "Engineering Disasters" on the Discovery channel about concrete ceiling slabs installed in tunnels on the Big Dig project..
The bolts were epoxied and still failed.. leading to a few deaths and millions in repair costs..
Even with a engineer stamp.. I would find a way of installing a few of these as a backup just in case..
I have seldom seen wedge anchors fail if concrete was good. I have never been able to pull one out of the hole in good concrete.
I trust the wedges for holding static loads with the loading mostly lateral along the surface. The problem with a light pole is the load oscillates in a direction that tends to defeat the wedge. Plus there is the cracking concerns with concrete dimensions that are relatively small.I may just be paranoid, but I would be worried about using those in a pole base. I think of how easy it is to split rock using feathers and wedges, so I really don't like the lateral force of those wedge anchors pushing sideways on the pole base. I have no problem with those in a large slab, but would much rather see, an engineered solution, using epoxy and all thread. Anyone have any thoughts on this?
Seems logical. I was imagining a pole base splitting open one day.That would be my concern as well with a pole base.
I like this idea.Is it possible to move the light to the right position on the pole or can it only fit one way?
