malachi constant
- Minneapolis
In doing a punchlist I noticed what appears to be corrosion on all the pole base anchor bolts (see attached bmp). Specs call for hot-dipped galvanized bolts. I'm the engineer. Municipal project in the upper midwest (extreme temps, lots of moisture, can be windy, lots of salt on the road). Poles are aluminum, 12' tall on 3' riser (15' total).
I'm looking for some help here. I'm not an expert on hardware, but these look like they are corroding and not galvanized, and I am concerned. Should I have these taken out and the correct bolt installed? If so does that mean the entire base should be repoured? Or is this a non-issue and they will hold up fine over the years?
I don't want to go overboard and be overly burdensome in the punchlist, but if this is a potential safety issue I want to get it fixed. Thanks.
