dcsva@aol.com
- Virginia
277V/400 Watt Pole Lights
The contractor wants to install 3-Single Pole circuit breakers to feed 9 pole lights.
Circuit-1 on Phase-A, Circuit-2 on Phase-B and Circuit-3 on Phase-C.
Three lights per phase. Each phase is connected at every third pole.
One conduit extends from the building to all nine lights.
1. By using 3-Single Pole Circuit Breakers, are three sets (H,N) circuit wires required with a common ground? Or can we share the neutral also?
2. If all three circuits enter and then leave each pole light on the daisy chain, is a 3-pole disconnect required at each pole?
These pole lights are about 150FT apart.
