jonagman
- Orlando, FL, US
Hello,
I am trying to figure out whether or not, I need to install cutout disconnects with my pole mounted transformers. I have a primary line of 4160V feeding the transformers, one is 75KVA and the other is 37.5KVA, and both with 240/120V outputs. Is it required to have cutout disconnect switches with them? If so, what is the range of the current rating for each one that I should be using?
