bphgravity
- Florida
Many of the homes here in Florida use a Polyisocyanurate Insulation on the outer block walls and then faced with ?" furring strips for dry wall. This insulation board is typically 5/8" and has an aluminum facer on both sides.
The typical wiring is NM down the walls and secured with stand-offs to 4" sqaure boxes. The NM is kept 1?" from the furring strips but will be right up against the dry wall.
Any concerns in regard to this or is the possible hazard no more than it is with NM run along metal studding?
[ February 16, 2006, 03:38 PM: Message edited by: bphgravity ]
