rt66electric
- Oklahoma
I am installing a large pond pump in a fancy gated neighborhood.
The pump is a 7HP? submersible style, pumps a 3in discharge line 30ft uphill to a waterfall 300ft away.
Does a 220v 50amp spa-type breaker need to be installed? is it needed , or recommended??
The wiring provided with the pump, is S.O. cord routed through open water then up a pvc conduit located under the water's edge to the power box.
Thank you
Dennis
Thank you
Dennis
