mikeames
- Gaithersburg MD
- Teacher - Master Electrician - 2023 NEC
In my own garage I have a 20 amp MWBC with 2 GFI receps on it. Thats all this is on this circuit. This circuit is fed from a 100 amp sub I also installed myself.
In the same garage I have a fridge fed by a single 20 amp recep which is also feed from the same panel the GFIS are feed from.
Two days ago I put the fridge on a cheap $6 belkin plug in surge supressor, and today I wen to plug in a vacume to the GFI and they were both dead. They would not reset. (yes power was present). The GFIS have been fine and now all of a sudden the only change is the surge supresson and now their dead? Is there a connection? Why?
The reason I installed the cheap surge supresson is a learnign experience. I have a plasma TV in my living room that uses a HDMI balun or HDMI over a pair of Cat6 cables. When the fridge cuts out it causes the picture to blip or drop out for a secone. The reason is the balun needs a steady ground reference. When this is disrupted it will cause this error. This is documented. My thinking is the fridge is causing disturbance. I figured I would plug the fridge into a cheap surge protector to see if it made a difference. In the end it did not and at the same time blew out the GFIs??
The TV and baluns are already pluged into a surge supressor.
Any ideas or comments as to why the GFI were affected?
