A Home owner installed a pool 30 feet in diameter water level 4' deep 200 feet from his home and reliezed that a 14ga extension cord will not opperate the pump (12amps 115v). He is looking for a quick install for electrical hook up for the pump, and a pool light. However he also wants to put some outdoor lighting (load not known, Small pond with pump (load not known), and some general rec. for a gazebo. All these items are located 200' from his home.right now alls he wants is power to the pump and pool light. the rest is future.What i was planning to do was install a 60a subpanel and the run uf cable from the home to the panel. Then either in pvc or uf to the rec. for the pump, and light. The homeowner will do the trenching. and install the posts for the recs. and subpanel. cable length to feed the subpanel will be 220' then use about 10' pvc to feed conductors to the panel, and on the other end use pvc with an lb to feed into the home. another 80' run for the rec. for the pump and light.Most likely i will use pvc with 12ga thwn for the run 3 hots 2 nuetrals ground. Outdoor rate rec. box with locking capability single rec. use a spit circuit duplex rec. for the light. I'm still looking into the grounding requirements for the pool.I Believe voltage drop will play a factor. so the feed conductors need to be a #3.What do you guys think of this project? More info needed? What would be your cost in your areas? Oh yeah one last thing. I gave the homeowner a price to expect from $3,000 -$4,000 he about fainted. He was looking at $1,000. I think the biggest price will be the wire.thanks.
