jeffegg2
- Westland, Michigan, USA
One of your illistrations shows the connections, but it is not really clear.
The code says 12AWG ground to the motor circuit, and 8AWG for the EPB.
My question is not that they must be connected, but where to connect them.
At the Motor casing?
At the motor outlet?
At the house?
How far back to take the #8?
If I only went to the motor housing, then suppose they used a double insolated motor?
If I have the motor circuit coming from the house to the motor in PVC with PVC outlet boxes for the switch and outlet should I drill a hole in the bottom for the #8?
An update to the NEC should make this more clear....
Thanks.... Jeff
At the house?
Thanks.... Jeff
