Hello all.
1) Could someone direct me to Mike Holtz cartoon character on pool bonding. Reason I ask is that I remember seeing that the equipotention bond grid and associated bonding of equipment did not need to get tied
into the ground bar of pool associated sub panel (I could be wrong, would like to check).
2) Feed to pool sub panel. Ground needs to be insulated. Does that feed need to be continuous with no splices or are boxes permitted in that run (eg: MC to box to pvc to pool sub panel)?
3) Would other circuits and or switch legs be permitted in that feed conduit?
lastly:
4) Pool light: if a pool light is to be controlled from a switch (single or 3 way) located in a house, can the wiring method be RX or would MC be necessary?
Thanks guys.
Been a while.
Hope all's well and thanks for the help.
Rich
lastly:
Thanks guys.
Been a while.
Rich
