Thanks for the reply. I prefer to find an appropriate connector to tie two #8's together directly instead of using a piece of rebar as a connector... I will have 5-6 pig tails coming from the pool structure and light niche's that will be installed at pool build time, and will need to tie that to the main #8 loop around the pool that goes to the pad. Is it customary to install that loop before the gunite is shot? I was going to only install the tails before gunite, then once the pool is backfilled, install the loop and tie to tails. Seems to me the loop wuold only get in the way or get damaged if installed before gunite. Is it normally done differently? ANy pointers on a connector listed for direct burial #8 to #8 connection would be greatly appreciated.
