sidewinder770
Hi all. I have been to this forum several times and found most of what I needed to know by reading other threads but now I need a little help and can't seem to find the answer elsewhere. I don't do much work on pools at all so when it's a little out of the norm I figure it's best to ask for help from the pool experts. Hopefully I posted this in the right section.
Here's what I got- I'm helping a friend install a subpanel for a pool equipment relocation project. That's pretty straight forward and were actually using GFi breakers on all circuits even ones going to some fixed horse arena lights because he wants to be over safe.
The problem we're running into is the pool bonding. The pool light is in a red bronze conduit to a deck box (already existing) and will be moved a little but no extending of the conduit/pool light will be needed. The deck box will end up being about 15 feet away from the other equipment (sub panel, pool pump, blower motor, etc). He has dug around all the existing plumbing and pool light pipe and is ready to relocte them when I found out he has no bonding wire from the pool grid (inground pool about 20 years old). I thought that was kind of odd so I'm not sure what to do about the light and the bonding now as I was planning to just extend the bond wire to the equipment area but now that I see there isn't one what do I do? We will be extending the pool light from the deck box to the new panel using PVC which from what I know is acceptable but how do I bond the equipment without a bonding wire from the pool? we didn't want to have to extend the bronze pipe to the equipment area because of cost and also because he would have to buy a new pool light since the old cord would be to short. Can I attach a #8 bond wire to the bronze pipe for the pool light (at the deck box) and bring that over to the equipment area? I'm thinking it might be a good idea to put a ground rod in by the new equipment as well to bond to just to be safe but I want to make sure all this is up to code. Just kind of weird that there is not a bond wire from the pool but maybe back then they just used the bronze pipe as the bond?
any help would b great and thanks!
