I have noticed on my Pool that the copper bonding wire is not connected to any of the devices, (pumps heater etc). What I have is a copper wire loop about 2 ft tall exiting and then entering the earth right next to the devices. My logic tells me to cut this and using a metal strip connector and the correct copper guage wire connect in all the devices. Having said that I would like to test whether the bond wire is correctly attached to the pool to begin with. ie: I don't want to go and hook up motors and the like to a bond that for all I know may be open circuit to the pool shell. Is there any way I can test this? I am skilled in the use of ohmmeters / voltmeters. I have wired up to and including 3 phase a.c in past jobs as a Computer Engineer and Electrician, (not as a diy hobbyist).
Thanks
Thanks
