I will run the solid #8 copper 18-24 inches around the above ground pool at 4 to six inches deep....I will bond the pool pump motor... completing a full circle around the pool
I need to bond four points around the pool....the ladder is plastic....
I will bond the water in the skimmer via the listed plate....
My question is the pool liner is metal....but the vertical structural supports are plastic...
.am I missing something?
Is there a way to bond the metal liner?
Also...there is a low voltage light that is part of the jet... The jet brings the filtered water back into the pool....I plan on mounting the transformer 6 feet away and plugging it into single outlet that will be on the same circuit as the pool pump....
I looked and I didn't see a way to bond the light or the transformer....I saw nothing in the directions....does it have something to do with the isolated secondary winding of the transformer?
Thanks
Thanks
