redwolf056
- Florida
- Electrician
Customer did a major renovation to a home he purchased. Pool was existing. I'm coming in after the fact. In old photos pre-reno there is what looks like the bonding wire connected to the pool pump. Pool contractor never kept track of it and that wire is buried somewhere now (a concrete footing went in near the equipment so the ground was torn up around there, not sure where the wire is now). Electrician who worked on the house "thinks" he remembers the pool being grounded to the house though, but the job has taken over 2 years so his memory is fuzzy. Pool contractor's main employee may have done something like that, but he quit and disappeared a while ago so can't ask him. Pool deck and turf have already been installed and customer now wants to know if his pool is grounded without tearing it all up. Pool has nichless LEDs the require no bonding, and there are no metal handrails at the steps. I don't see any exposed screws anywhere expect in the skimmer. There is an existing levelor, not sure if that was part of the original bonding. Questions now are -
1) Can I use an Ohm meter to test for bonding if I don't have the ground wire to attach to? Even if I did have the ground wire, what could I even connect the other contact to? Is there some other way to test?
2) Customer is asking what risks he faces if the pool isn't bonded (outside of lightning)?
Thanks for any help/advice.
