pool bonding
LYLE2231
I am trying to identify the article that requires metal window frames, door frames that are within 5 feet of the waters edge of the
in ground permanent pool. Anyone know? I've been thru 680 and 250 parts V * VI* VII with no luck.:cool:
I don't know I personally think it is ridiculous. I believe you have to install ground lugs or cad well.
Since the window tracks are probably not rated to provide ground continuity from the pane to the frame, you also have to choose a window position and weld the window to the frame. :)
