Pool Bonding
guschash
Ohio
When bonding a above ground pool ( circular) , and I bond the motor do I just leave the end that's not attached to anything,just curled up by pump motor or can it be attached also to pump motor? Also how would I bond the water if the ladder is plastic? The pool was up and filled before I got there.
Thanks Gus
Thanks Gus
I don't know what you mean by the part in red above. If you have already bonded the pump motor why would you connect again to it?
Also to add to what cpinetree linked to, I use this a lot for the water bond. It goes in the filter basket for the pump.
