toro
New User
- Grand Rapids Ohio
- administrator
I have a new fiberglass inground pool. They poured a 12 inch concrete coping then 5 feet of stamped concrete. Did not install the copper bond wire under the concrete. There is no rebar in concrete. Failed County inspection. So they sawed out 8 inches of the 5 foot concrete next to the coping installed the copper wire and installed paving brick to fill the cut area. Copper bond wire is connected to the bond lug on the pool pump. Problem is the coping concrete, brick etc. is not bonded. I have followed Mike's video step by step. Any idea of the problem. Than You, Chad
