russ__20000
Can anyone tell me the safty reason behind this bond and what year was it added to the code?
The reason I am asking is cause the VD that this bond causes is a pain to deal with.
The utlity doesn't want to help and I can't climp up on their poles or go into everyones house and check their netrual connections or if someone has a ground short.
It seems to me, if all circuits were GFI protected, this bond would not be needed and the "stray voltage" would go away. The code will not even recognize stary voltage , as it relates to pools.
Does anyone know of some sort of "ronk blocker" that can be put in the bond to stop current from flowing, under 1 or 2 amps. This would stop it, but would this violate the pool bond code?
Any comments?
Any comments?
