Pool bonding
dej
New member
It was told to me that the bonding conductor #8 of the pool equipment and pool shell can not be together on the same ground bar kit as the grounding conductor. The reason is never shall the panel ground and bonding conductor be tied together. If this is true, do you insulate the lug on a motor from the frame because the grounding screw is tapped into the frame. Similarly the bonding lug on the deck box is directly conected to the grounding bar in the deck box, and the wet niche ground is bonded to the shell of the pool. Most equipment on pools contain a bonding lug and an internal grounding connection, both are tied to the same frame. Am I correct in my thinking
Before anyone answers this question, let me ask the originator to explain the information shown on the profile page. Occupation: er. Relation to the electrical industry: contractor. In the mean time, I will temporarily close this thread.
Forum rules do not allow us to assist a person who is not employed in the electrical industry. If you are, for example, a mechanical or HVAC contractor, then we would not be permitted to help you perform your own electrical installation work.
Please send me a reply via Private Message. If you are, in fact, an electrician, I will reopen this thread, and offer an apology for the delay and inconvenience. I would also suggest that you correct your profile accordingly.
