have to go on a bid for a above ground pool install. Reading up on code it appears that if the waterline on the pool is not greater than 42" there is no need to bond if pump is double insulated 680-30. But if it is greater than 42" then you must bond. Is there fittings for bonding above ground pools? do you have to bond every leg or just a one point at pool? 680.26B4 (2002)states that if a double insulated pump is used you still must pull bond wire to pump and connect to EGC of motor circuit. I can see why you pull bond wire in case a replacement non double insulated pump is used as a replacement but it doesnt seem right to tie bond wire to EGC for insulated pump. Any info or comments would be greately appreciated. This is my first post with the new format. Still trying to get used to it
