('08 Code) Above ground pool, metal frame, less than 42" of water.
Any equopotential bonding needed ?
Storable Swimming, Wading, or Immersion Pool. Those that are constructed on or above the ground and are capable of holding water to a maximum depth of 1.0 m (42 in.), or a pool with nonmetallic, molded polymeric walls or inflatable fabric walls regardless of dimension.
III. Storable Pools
680.30 General.
Electrical installations at storable pools shall comply with the provisions of Part I and Part III of this article.
Where does the definition state that. There is no mention of what the pool is made of in the first part.Since it has a metal frame, is it still considered storable????
You're the inspector. :grin:
From a code stand point, the bonding is not required, but from a safety stand point, why isn't it required? The code rule should be based on something other than the wall height. If you have two pools with identical electrical equipment and one with a wall of 36" and the other with a wall of 48", is there really any difference in the possible safety issues with the two pools?
