pool-misery
I've had 5 electricians to my home for plans to abandon current underground wire that services our detached garage. Our above ground pool equipment has been running off this power source since 1992 via extension cord to garage receptacle. However, I am very concerned about safety since buried service pipe travels directly under the pool to the garage. I want to run new power from house to garage AERIALLY, with new sub-panel in garage and then run separate GFI circuits to pool filter and propane heater.
Each electrician has given differing clearance restrictions. I'm really frustrated with the run-around.
I specifically need to know:
1. What is the minimum horizontal distance allowed from the edge of the pool to the overhead wire.
2. My pool filter and propane heater are very close to the wall of the pool (at best 3 feet). Is there any allowable way to connect this equipment without relocation of the equipment? Some have mentioned twist locks.
3. Is the use of above ground conduit allowable from the panel in the garage to the pool equipment if it is secured to stockade fencing posts and rails?
We would rather not dig our yard to bury new wire.
If I can get straight and reliable answers, I may be able to use one of the electricians I've interviewed.
Thanks!!!!
Thanks!!!!
