Through an odd set of events, including a building inspector's stroke, I've been directed to conduct 2 continuity tests on a pool bonding--one test is simply from one end of the bonding wire to the other, a no-brainer and certain to succeed. The other test is from the remesh in a concrete deck, already poured, and the bonding wire as it emerges from the concrete at the pool pump. I did a quick check of the conductive nature of a scrap of remesh before attempting to dig through the concrete to the actual remesh to be tested. I discovered that I really had to scrape into the remesh in order for the test to succeed. Even if I had successfully bonded one 4-foot strip of remesh, the next adjoining strip, being metal-wired tied to the first, will not carry the current for continuity. Any suggestions on how to deal with this catch-22 imposed on me?
