Hi.
I’ll be wiring a heater for a pool.
The circuit will be a couple hundred feet underground so I’m thinking of installing a regular breaker inside at the panel and install a gfci at the pool heater instead of at the panel to help prevent tripping.
Does the neutral on the gfci have to be connected to anything or can it just be capped off and float ?
Thank you
Thank you
