Pool LED and GFCI
Peter G
New User
Los Angeles CA
General Contractor
Having a new problem with an old installation. About 3 years ago I installed the Zodiac upgrade board into a Jandy One touch system thus upgrading it to support LED RGB bulbs. The system has worked flawlessly until last month. There are 5 spa niche sized fixtures all wired to a Jandy relay that is wired after the GFCI. All wiring is in conduit running out to the various locations around the pool.
First step I have taken is to replace the GFCI and the lighting worked as it had been before for about 3 weeks, then it stopped again.
I have visually checked the individual light fixtures to see if any moisture is visible, nothing is apparent.
I replaced the GFCI again and the new one (out of the box) trips immediately. I am going to pickup another GFCI just in case the last one was defective.
What should be the next step in troubleshooting this problem?
We have been working on sprinklers in the general areas that the Pentair Pool Junction boxes are located, I have not scene any evidence of damage or being sprayed with water.
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
Since the OP hasn't answered the question by Dennis, we'll have to close this thread according to the Forum rules.
@Peter G
If you have the license you can PM one of the Mods and we can re-open the thread.
