pool light junction box
nizak
If the cord assembly for a pool light is long enough to reach directly to the pool equipment area does it have to terminate specifically in a listed pool junction box? I have 4 pool lights all within 75' of the pool control panel, seems unnecessary to go thru j-boxes to get to final termination.
The light junction box can be omitted if the transformer is listed for this. The ones I've seen are just a standard pool light transformer and you order a kit that makes it suitable. As I recall Intermatic makes a kit for this. See 680.24(B).
Take a look at 680.24. If your pool control panel meets all those specifications for 4 lights (I heave not seen one that does) then you can omit the box. They do make listed pool boxes for more than one light.
http://www.intermatic.com/en/Produc...res/Accessories/PJB_J-Box_Series/PJB4175.aspx
Presumably any pool control panel with the appropriate listed adapter can be used.
http://www.intermatic.com/Products/Pool_and_Spa/Accessories_and_Enclosures/Accessories/Panel_Parts/J_Box_Hub_Kits.aspx
