enireh
- Canyon Lake,TX
line into GFI plug load out neutral and ground to light, load side hot to switch, switch leg to light. GFI is tripping if I bypass GFI the light works
off of the power to the time clock for pool equipment it feeds a GFI pug which feeds off the load side the neutral goes to the light and the ground. the hot off the load side goes to the switch and the switch leg goes to the light and it trips if I bypass the GFI plug the light works
