Jimmy7
- Boston, MA
- Electrician
I’m not typically a pool guy, so is this okay. I used this pool light transformer provided by the homeowner. This is for one pool light that I believe is LED. The light has a cable attached that contains two yellow wires with no ground. The transformer states 3 amps max input, I put it on its own 15 amp Eaton BR afci/gfci breaker (Pool panel states BR Cutler Hammer) I did everything with #12. I ran from the breaker to the switch then to the transformer to the pool light junction box. I terminated the grounding conductor at all of those points. At the transformer I tapped off the 14 volts with two #12. ( I believe there was a note for Hayward lights to use the 14 volt tap). I attached both of the #12 to the yellow wires coming from the pool light cable in the pool light junction box. I then terminated the only ground there was (From the transformer, not the light) to the ground bar in the pool light junction box. What do you think?
