Greentagger
- Texas
- Master Electrician, Electrical Inspector
In relation to 680.23(B)(2)(b), would the #8 insulated bonding jumper be required in a low voltage led pool luminaire. Noted is the language “not required a listed low voltage lighting system not requiring grounding“. If the forming shell comes with a lug on the inside of it , might this be construed that this needs to be grounded then even being low voltage below the contact level would require this additional #8? The forming shell is metal and not one of those small poke thru wall lights in a 2” sleeve. Thanks for some clarity.
