I stopped by a friends place and was told that his lighting doesn't work anymore. I checked the circuits by unwiring the connections and individually checking the ohms on each one. I noticed that the ohms were around six to ground. I then re-attached the circuits individually to have each time the GFCI tripping out. I also proved to the owner that the GFCI was not at fault by plugging a big floor fan to the circuit thus causing no trip out. Could the wiring have been compromised with the underwater lighting? And I personally don't feel comfortable with 120 volt lighting versus low voltage such as 12 volt DC. Any suggestions??
ascomm@frontiernet.net [/LIST]
